When adding a new layer to a map (in both Map Viewer and Map Viewer Classic; it would be really useful to have the option for the layers being added not to be prefixed by the name of the map service they came from.
If you have a map with lots of layers, manually renaming becomes a tiresome task.
In the example above, I just want the name of the layer as it was published from ArcGIS Pro, not the layer, prefixed by the name of the service.
In fact, i think this should be the default, as the service name is really only used for service management purposes in the majority of use cases I can think of.
