We have a few map packages MMPK loaded into our android app, and user can switch between the maps.
When switching between the map packages, it seems that a particular MMPK, created from a TIF file, would sometime crash.
Following is the crash log from logcat
E/AndroidRuntime: FATAL EXCEPTION: Rendering thread
Process: myapp.debug, PID: 17245
com.esri.arcgisruntime.ArcGISRuntimeException: Invalid argument.: get_coordinate_system_type() == Spatial_reference::local || !is_pannable
at com.esri.arcgisruntime.internal.jni.CoreGeoView.nativePulse(Native Method)
at com.esri.arcgisruntime.internal.jni.CoreGeoView.n(SourceFile:619)
at com.esri.arcgisruntime.internal.i.b.g.h(SourceFile:1108)
at com.esri.arcgisruntime.mapping.view.GeoView$RenderingThread.doFrame(SourceFile:1549)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:997)
at android.view.Choreographer.doCallbacks(Choreographer.java:797)
at android.view.Choreographer.doFrame(Choreographer.java:728)
at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:984)
at android.os.Handler.handleCallback(Handler.java:883)
at android.os.Handler.dispatchMessage(Handler.java:100)
at android.os.Looper.loop(Looper.java:237)
at com.esri.arcgisruntime.mapping.view.GeoView$RenderingThread.run(SourceFile:1293)
I/Process: Sending signal. PID: 17245 SIG: 9
Appreciate any advice thanks!
Android ArcGIS Runtime: 100.10.0, we are using Java
