I have been testing the new SAS toolset in ArcGIS Pro 2.8, since my organization has many SAS programmers our GIS team collaborates with. It's within the Conversion Tools. I have been asked to test out these SAS conversion tools. While trying to run the SAS to Table & Table to SAS, every time they fail within 10 seconds at most. I have tried running them through the geoprocessing window as well as arcpy. On my PC, I have both base SAS 9.4 as well as SAS Enterprise Guide 8.1. I have been trying to import a sas table where the rows are ZCTAs in my state. There should not be any issues with the structure of the table, it's set up in a way that should be able to join to ZCTA GIS data.
SAS to Table Inputs
Input SAS Dataset (libref.tablename): work.ZCTA_WOCBA
Output Table: O:\_Projects\Misc Reference Map.gdb\SASToTable_ZCTA_WOCBA
Download SAS Dataset from SAS Cloud Analytic Services (CAS): LOCAL_SAS
CAS Hostname URL:
Port:
CAS Username:
Password:
Results (after 10 seconds)
File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\SAS2Table.py", line 101, in <module>
casUserName = casUserName, casPassword = casPassword)
File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\SAS2Table.py", line 64, in __init__
sas, scratchCFG = SAS_UTILS.getSASSessionInfo()
File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\SAS_Utilities.py", line 84, in getSASSessionInfo
sas = SASPY.SASsession(results='TEXT', cfgfile = scratchCFG)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\saspy\sasbase.py", line 537, in __init__
self.pyenc = sas_encoding_mapping[self.sascei]
KeyError: 'No SAS process attached. SAS process has terminated unexpectedly.'
Table to SAS Inputs
Input Table: ZCTA_wCensus2019
Output SAS Dataset (libref.tablename): work.ZCTA_wCensus2019_test
Replace SAS Dataset:
Use Domain and Subtype Descriptions:
Upload SAS Dataset to SAS Cloud Analytic Services (CAS): LOCAL_SAS
CAS Hostname URL:
Port:
CAS Username:
Password:
Results (after 2 seconds)
File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\Table2SAS.py", line 152, in <module>
casHost = casHost, casPort = casPort, casUserName = casUserName, casPassword = casPassword)
File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\Table2SAS.py", line 56, in __init__
The only demo of this tool I've seen is here: https://www.esri.com/arcgis-blog/products/arcgis-pro/analytics/introducing-the-sas-arcgis-bridge/ and there does not appear to be any additional steps taken that I've seen. What am I missing?
