Hi... I'm using an ESRI sample code for connecting a Secured Feature service using PROXY method.
My organization setup is Server federated with ArcGIS Portal.
I'm hosting the application from my local machine for testing purpose.
I tested using the mentioned URL below, and I'm getting response.
http://localhost/DotNet/proxy.ashx?https://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer?f=json
When tested with
http://localhost/DotNet/proxy.ashx?https://mydomain/server/rest/services/Channels/FeatureServer/0?f=json
i receive the error.
{"error":{"code":499,"message":"Token Required", "details":[]}}
The user and password I'm using to access the secured service is created from portal with admin privileges.
I've attached the code, proxy configuration and the response from JS for your review and i'd like to know whether I'm missing something or committing any error in the code.
<script src="https://js.arcgis.com/3.37/"></script>
<script>
var map, cred = "esri_jsapi_id_manager_data"; // cookie/local storage name
require([
"dojo/_base/unload",
"dojo/cookie",
"dojo/json",
"dojo/parser", "esri/config", "esri/IdentityManager", "esri/layers/FeatureLayer",
"esri/map",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/domReady!",
], function (baseUnload,
cookie,
JSON,
parser, esriConfig, esriId, FeatureLayer,
Map){
// store credentials/serverInfos before the page unloads
baseUnload.addOnUnload(storeCredentials);
// look for credentials in local storage
loadCredentials();
parser.parse();
esriConfig.defaults.io.proxyUrl = "http://localhost/DotNet/proxy.ashx";
esriConfig.defaults.io.alwaysUseProxy = true;
esri.config.defaults.io.corsEnabledServers.push("MYDOMAIN");
map = new Map("mapCanvas", {
basemap: "topo",
center: [27.00, -6.00],
zoom: 3
//add the secure service - token is required
var secureLayer = new FeatureLayer("https://MYDOMAIN/server/rest/services/Channels/FeatureServer/0",
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ["*"]
map.addLayer(secureLayer);
function loadCredentials(){
var idJson, idObject;
if (supports_local_storage()) {
// read from local storage
idJson = window.localStorage.getItem(cred);
else {
// read from a cookie
idJson = cookie(cred);
if (idJson && idJson != "null" && idJson.length > 4) {
idObject = JSON.parse(idJson);
esriId.initialize(idObject);
else {
// console.log("didn't find anything to load :(");
function storeCredentials(){
// make sure there are some credentials to persist
if (esriId.credentials.length === 0) {
return;
// serialize the ID manager state to a string
var idString = JSON.stringify(esriId.toJson());
// store it client side
// use local storage
window.localStorage.setItem(cred, idString);
// console.log("wrote to local storage");
else {
// use a cookie
cookie(cred, idString, {expires: 1});
// console.log("wrote a cookie :-/");
function supports_local_storage(){
try {
return "localStorage" in window && window["localStorage"] !== null;
} catch (e) {
return false;
</script>
