Dynamic pictures can only be added to the Details section of a report, which means I can't take advantage of the Reporting functionality in Pro. I have an ArcMap workflow that runs LOS analyses on multiple Viewer Points to check the visibility of multiple Site Points. After the analyses are run, I generate a report that divides each page by Viewer Point and includes an image of the map showing the results of just that Viewer Point. The report is HTML rendered into a WinForms WebBrowser control so users can print to PDF (the client tends to frown on third-party libraries). I would love to use Pro's reporting engine to save the users the additional step and avoid the workaround, but right now I can't because of the dynamic picture restriction.
The attached image shows how I want to divide the report pieces in the designer. The Group Header and Details sections translate fine, but I can't add a dynamic image to the Group Footer.
