I have a form that uses the pulldata() function to create a JSON from hosted feature layer in my AGOL account. I then use the pulldata() function again to populate two subsequent questions from the JSON script, which works great.
The issue I have is trying to use a choice_filter based on the values from one of the previous questions that used the pulldata() in the calculation field. I am not getting any choices in the drop down. When I don't use the pulldata() function in the other questions, and just use the select_one then I am able to get this to work.
