I am trying to sum our plant production from multiple sources.
var portal = Portal("");
var fs = FeatureSetByPortalItem(
portal,
1,
"Date_",
"W_F_MGD",
"E_F_MGD",
"TOTAL_W_E_MGD",
"TID_FLOW_MGD",
"REEDER_Percent_FULL",
"TAP_FLOW_MGD",
"PLANT_PRODUCTION_MGD"
false
// Find the most recent date from the date field to filter the FeatureSet for the latest record
var TotalProduction = Round(Sum(fs, "PLANT_PRODUCTION_MGD")+Sum(fs, "TAP_FLOW_MGD"));
return TotalProduction;
I want to sum the TAP, TID, and Plant production fields. I am getting errors even with the code above. What am I doing wrong.
Update:
using this I was able to sum in the script
https://www.esri.com/arcgis-blog/products/ops-dashboard/announcements/introducing-data-expressions-in-arcgis-dashboards/
Test shows a result but I cannot select it
