I have over 20 layers that I need to spatially join, doing separate arcpy.SpatialJoin_analysis for each one would be time consuming. fc1 is the layer I want to multi batch the other layers in the database to.
I have tried the following but it only spatially joins the first layer in the database. Is it possible to do a multi batch spatial joins? I am going about it the wrong way?
import arcpy, os
from arcpy import env
from datetime import datetime as d
startTime = d.now()
arcpy.env.workspace = r"C:\Temp\Default2.gdb"
fc1 = r"C:\Temp\Default2.gdb\Parcels"
fcs = arcpy.ListFeatureClasses() #gets the feature classes
for fc in fcs:
print(fc)
arcpy.SpatialJoin_analysis(fc1,fc, "SP_Test", "JOIN_ONE_TO_ONE", "KEEP_ALL", "", "INTERSECT", "", "")
print ('(Elapsed time: ' + str(d.now() - startTime)[:-3] + ')')
fc1
