Experiencing issues with copying graphs to map as a graphic / adding them to layout. I'll attach a photo to show what happens when I add the graph as a graphic (bottom) and add the map to the layout (top). They each have an extra bit of space on them that is either white for copying the graphic or black for adding to layout. I have tried adjusting the background color (none set), tried going into advanced properties, trying to figure out a way to crop it and nothing has work. I set a border on the copied as a graphic one on the bottom so you can see the extent of the error against the white background. Thanks.
I have the same issue. everything was fine and suddenly any graph added to layout has the black background. I have tried turning off different adjustments in properties.
Anybody figure out the problem
