Hello Everyone,
We are publishing image services with raster attributes defined as this NLCDL Sample where both the RGB values and Classes reside with the raster attributes.
Our rasters do have the Class but no RGB values in their attributes. Is there a way to add these RGB values manually in the attribute table within ArcGIS Pro?
We did add them to an img file using ERDAS Imagine but publishing it as an image service from ArcGIS Pro does not show us the attribute table. This issue occurs even while exporting the raster in ArcGIS Pro to a TIFF.
We are sure this can be done in ArcGIS Pro only and it would be great if you could let us know if we are missing something or is there a set workflow to manually add the values.
