Hi Everyone,
I have created a survey through survey 123 connect using version 3.12. The goal is to capture certain information for specific properties. However the enumerator must capture the correct information for the correct property, I've therefore used geoshape and geopoint so the person can see his location. However, the polygons are not pulling in on the map, and I'm also struggling with the pulldata and the script. I've added the featurelayer (with all the polygons) manually to the web map that gets created once the survey is published, but I've been told that it would be static. The survey must be public, and hence I'm getting an error on the output that scripts are disabled. I'm just failing 100% all round. Hoping that someone can help me. Below a screen shot, and attached my excel and script file. Please note that I am extremely new to scripting.
