Hi S123 Community,
Goal
Output coordinates in New Zealand Trans Mercator (collected through geopoint in the S123 form) via the report template, which would then be sent out automatically to the signee using Integromat.
Context
Field workers will be taking the form offline. They will mark a point where water is, using the geopoint question. I have gotten the basemap offline. So far so good. The field workers are in New Zealand though and require the coordinates to appear in the report in numerical format in NZTM, not as a point in the map and not in WGS84. From what I can tell, there are only select coordinate systems that S123 uses.
Is there any way to output the coordinates in NZTM? I have figured out how to grab the coordinates in WGS84 into the report.
If there's not, does anyone have any work around or suggestions to get to the goal? I've thought about trying to convert from WGS84 to NZTM using calculations in S123, but I am still new to S123 and don't have much experience with projections. I normally would convert via online converters or using tools in Arc, so I don't know the actual manual way of doing it. I prefer not to do it either of these two ways though because we want to have the process automated from signing straight to sending a copy of the form to the signee's inbox.
This post also asks when S123's geopoint feature will use non-WGS84 coordinates.
