I'm very interested in use ArcGIS Survey 123 for collecting data and for making QA. I wouldn't want to use an application external than Survey 123 for QA stages.
So, is Survey 123 capable of being that QA application? Could the QA personal receive the 'new' surveys with a filter in an hidden field (that could be named status) and return as 'rejected' to field workers, using the same Suvey123 app, but changing the original form to a revision form as James Tedrick was expalaining in this other post: https://community.esri.com/t5/arcgis-survey123-questions/reject-submitted-answers/m-p/1058576#M34650?
And, Is it possible with Survey 123 to copy the answers from the original survey to a revision survey that include the comments fields, or we need to use a script? Could we change the status of a comment field from editable for the QA personal to read only for the field workers in the revision form with some function in Survey 123?
Could you give me some examples or a guidance for do this with Survey 123?
Regards,
Luis
