Hi I am taking a remote sensing class and this week we made a composite image with Landsat 8 bands. When I generate this composite image it is only visible when I zoom in to around 1:560,000. But I need to make a map at a larger geographic scale than that and any smaller/coarser scale and the image disappears.. Googling the issue makes it sound like I need to adjust the MinPS and MaxPS but it says that is done in the attribute table and none of these layer have the attribute table option highlighted to access or edit.
Other things I've checked: visibility of the layer is set to "none" for when to not show the layer (in the layer properties), transparency is 0%, and the layer is clicked "on" in the table of contents.
