I need help figuring out which Map Viewer to use. The help states:
"Caution:
If you're using ArcGIS Enterprise to configure the map with the Field Maps web app, you must use Map Viewer Beta when editing the map. If you use Map Viewer to edit the map, the changes you make in the Field Maps web app will be lost.
If you're using ArcGIS Enterprise 10.8 or earlier, see Configure the form in Map Viewer Classic."
But Map Viewer Beta is no longer Beta and now just Map Viewer. So I cannot use Beta and this states changes to the Field Maps will be lost if not using Beta. Our Enterprise is 10.8 and moving to 10.9 so Classic is a no go for us. Can anyone enlighten me on which to use please?
https://doc.arcgis.com/en/field-maps/android/help/configure-the-form.htm
