I am stuck here. I need to filter a feature set by a date a value. I set up this up but on lie 7 for the "cnt" variable I am getting "Failed to Query statistics", but If I pull out the "AND MMS_Date_Turning >= @current_year" section from my filter it works fine.
This query fails:
var quad = $feature.Quadrant;
if ($feature.Quadrant != null) {
var current_year = Date(Year(Now()),0,1)
var System_valve_set = filter(featuresetbyname($datastore, 'sValve', ['OBJECTID', 'WATERVALVETURNING_STATUS', 'GRID_NUM', 'MMS_Date_Turning'], false), "GRID_NUM = @quad AND MMS_Date_Turning >= @current_year")
var cnt = count(System_valve_set);
if (cnt > 0 ) {
var query = "WATERVALVETURNING_STATUS = 'Closed'"
var System_closed_valve_set = filter(System_valve_set, query)
var closed_cnt = count(System_closed_valve_set)
if (closed_cnt > 0){
return count(System_valve_set) - count(System_closed_valve_set)
else {return count(System_valve_set)}
else { return null }
else { return null }This query works:
var System_valve_set = filter(featuresetbyname($datastore, 'sValve', ['OBJECTID', 'WATERVALVETURNING_STATUS', 'GRID_NUM', 'MMS_Date_Turning'], false), "GRID_NUM = @quad")
if (cnt > 0 ) {
Regards,
Jim
