I have a problem with an input field that is supposed to be used to enter decimal numbers.
It is not possible to enter the decimal comma in the Survey 123 app on Android devices. No comma appears on the keyboard. If I use the point instead, it also only stores an integer.
I am using version 3.12.277 with Android 11 (in Germany).
The problem occurs when I create the survey via the web designer, but also with Connect.
Field is defined as decimal.
What am I doing wrong?
