Hi, I have created a survey in Survey123 where the participants marked their general location on the map - however, some of the responses are outside of my study area. I have created a buffer of the study area and would like to filter those responses that are within the buffer. I tried to filter by location in Survey123 but I am only able to filter by map extent and I am unable to add my buffer into the map layer - I am only able to add my buffer when I view my survey results in Map Viewer. I don't necessarily want to delete the survey responses that are outside of the buffer. Is there a way I can filter by location using the buffer to select the points? Alternatively is there a way to create a copy of all my responses in Survey123 so that I can analyse one set of responses without fear of losing my data.
Thanks.
