I installed @arcgis/cli using 'npm install -g @arcgis/cli' on my Windows machine. When I create a new directory, cd into it, and then try to run the 'styles create' command, this is the error it produces:
C:\Users\cfb215.STATE\Desktop\testStyles>arcgis styles create newStyle
copying base
copying examples
copying preview file
arcgis styles create [theme]
Create a custom theme
Positionals:
theme the name of the theme to create [string] [default: "my-custom-theme"]
Options:
--version Show version number [boolean]
-e, --with-examples when specified, the created theme will include examples
from the API [boolean]
-b, --with-base when specified, the created theme will include base files
for local overrides (advanced) [boolean]
-f, --force overwrites a theme if it already exists [boolean]
-h, --help Show help [boolean]
NestedError: Cannot copy `preview/`: the file doesn't exist
at C:\Users\cfb215.STATE\AppData\Roaming\npm\node_modules\@arcgis\cli\node_modules\cpy\index.js:96:10
at runMicrotasks (<anonymous>)
at processTicksAndRejections (internal/process/task_queues.js:93:5) {
nested: undefined,
Is this a know or common issue? It looks like the file does exist but for some reason isn't able to be copied to the new
