I have a number of dashboards that contain layers of survey points and extents which are stacked for multiple years. When a year filter is applied (category selector in header pane using integer as year) the pop up for these datasets in the new version of dashboards shows all records rather than those that have been filtered.
The map filter is working, with only the features for the selected year drawing but the pop-up contains records for all years. This does not happen in Dashboards Classic where only the filtered record is shown in the pop-up.
I've tried changing the filter field to a text value and also reloading all layers from scratch to check no issues casued by recent appends. This behaviour is the same on different organisational accounts for similar datasets.
Is there now somewhere that the pop-up in the dashboard map element needs to be configured to only show visible layers?
Charles
