I was wondering if there was a way to repeat the same group of repeat questions in a survey or reference the repeat group?
I have a Manhole Inspection survey (built from an existing feature service) that contains numerous Pass/Fail questions. I'm trying to get all of the Fails to populate into a related table, called FMPs, to maintain the failures with their corresponding work order information. This table/repeat group needs to be applied to all of the questions. Is this something that can be done?
I have attached my spreadsheet with modifications to [hopefully] display what i'm trying to achieve. the Original related table repeat is boxed in, with the repeated repeat underneath each pass/fail question (in bold).
using Survey123 Connect 3.11.123
