Hello:
I am working on ArcGIS API 4.19 Dojo build up. When I ran "npm run build", It was fail. I checked log file. I got a error following:
error(356) The optimizer threw an exception; the module probably contains syntax errors.
module identifier: E:\TJPort\grid\jsapi-resources\4.x\amd\dojo\dist\esri\views\2d\layers\FeatureLayerView2D.js; exception: (compile time:0.245s). OPTIMIZER FAILED: JavaException: java.lang.NullPointerException: NAME NaN 127 [length: 6] [source_file: FeatureLayerView2D.js.uncompressed.js]
Can you supply any idea to fixe this one ?
Jimmy
