Can you create signatures in the forms like you can in Survey123?
If it is not possible, what is the best way to pre-populate a Survey123 form link (which would be opened up via a polygon pop-up in Field Maps) in a TABLET?
I want to carry over the GUID from the polygon to the Survey123 form to be filled out in a TABLET.
I've found you can do this through the form widget in Experience Builder, but the team is out in the field half the time and needs to be able to do this not in a web browser/offline.
