I have created a netcdf file and loaded it into ArcGIS Pro as a voxel layer. I can see that it is being read correctly because the symbology section shows an appropriate histogram for the data, and loading the file as a table also gives the correct data. However,it does not show up on my scene, no matter what I do. Originally I thought the file was too large, so I split it into sections (each about 33MB), and I have the same issue. What can I do to figure out what is causing this issue?
I have attached one of the smaller files if anyone would like to try to load it themselves.
