Hello All,
I am using Angular Typescript with ArcGIS API. Once I copied some sample codes from the documents, there are some bugs on it. I pasted the error message and my codes below. I marked the bugs in red colour.
error:
No overload matches this call.
Overload 1 of 2, '(properties?: GraphicProperties): Graphic', gave the following error.
Type '{ type: string; color: string; }' is not assignable to type 'SymbolProperties'.
Object literal may only specify known properties, and 'type' does not exist in type 'SymbolProperties'.
Overload 2 of 2, '(properties?: GraphicProperties): Graphic', gave the following error.
Object literal may only specify known properties, and 'type' does not exist in type 'SymbolProperties'.ts(2769)
My Code:
import { Component, OnInit, ViewChild, ElementRef } from '@angular/core';
import EsriMap from "@arcgis/core/Map"; import Graphic from "@arcgis/core/Graphic";
Component({
selector: 'app-map',
templateUrl: './map.component.html',
styleUrls: ['./map.component.css']
export class MapComponent implements OnInit {
map: EsriMap;
view: MapView;
constructor() { }
ngOnInit() {
// Add Based Map
const map = new EsriMap({
basemap: "streets-vector"
// add initial view, position, and zoom
const view = new MapView({
map: map,
container: "viewDiv",
center: [-79.502938, 43.767854],
zoom: 12
// adds the home widget to the top left corner of the MapView
var homeWidget = new Home({
view: view
view.ui.add(homeWidget, "top-left");
const track = new Track({
view: view,
graphic: new Graphic({
symbol: {
type: "simple-marker",
// size: "12px",
color: "green",
// outline: {
// color: "#efefef",
// width: "1.5px"
useHeadingEnabled: false
view.ui.add(track, "top-left");
// draw a point on a layer
const point = { //Create a point
type: "point",
longitude: -79.502938,
latitude: 43.767854
const simpleMarkerSymbol = {
color: [226, 119, 40], // Orange
outline: {
color: [255, 255, 255], // White
width: 1
const graphicsLayer = new GraphicsLayer();
map.add(graphicsLayer);
const pointGraphic = new Graphic({
geometry: point,
symbol: simpleMarkerSymbol
graphicsLayer.add(pointGraphic);
