I want to be able to include several default images in a survey for hydrant flushing. Each day the operator selects a flushing day (M-F) and I would like to be able to display a .JPG that shows the workflow for that particular day. Is there a way to construct the name of the image in the media::image column using the answer from another question? So for example, I use a select_one to capture the flushing day. Can I use this value somehow to display the corresponding .JPG I have created in the media file?
I tried using ${flush_day}.JPG in the media::image column but that didn't work. Can I use an if statement somehow? I have 10 different schedules (M-F, and two crews). Would I need to do that in a separate calculate question first?
Thanks!
