I am in the process of building a website that displays items on the map, part of the work I'm doing is drawing my own polygons using http://geojson.io and then I load them into my Postgresql spatial database. The polygons are being served over HTTP using my REST API in geojson format which is completely separate from my client.
I am building the client using ReactJS and I'm using the ArcGIS API. I am able to load the polygons over http and add them as a layer however, I am trying to encrypt that data in a way that only my application will be able to render them on the map since I'm spending a lot of time drawing these polygons and I would like to protect that work.
I have been looking around for solutions but I am not able to find something that looks like it would work well, my best solution so far is to somehow create a custom encryption and decrypt the data once it's loaded in the client and before creating my ArcGIS polygon.
Is there something built into the API that would help in some thing like this ? are there any better ideas to do this
I appreciate your help,
Thank you,
L
