I have need for the row id value of a record as input to the esri_editing_tableGoTo command which utilises the row id value to go to the specified record. When there is no definition query on the table, I can retrieve the record's object id value (using row.GetObjectId()) which in this case, is the same as the rowid value. When there is a definition query on the table however, the rowid and object id values are no longer the same. So in that case I need to retrieve the row id instead of the objectid. So how do I retrieve the row id of a record? @CharlesMacleod @Wolf
