I'm hoping to get some more guidance on best practices for using stakeholder views. I have a number of surveys published through survey123 connect which I regularly update and re-publish. In turn, I have to delete the stakeholder view and re-share the survey results.
I'm using dashboards to display results and apps to edit the data. Should I be using the original feature service with these or the stakeholder view? I normally avoid using the stakeholder view since I would have to delete it and reconfigure the app every time I update my survey.
