Edits I've made to joined tables will not show up on the map (or the joined layer's attribute table) without quitting and restarting Pro. Sometimes the edits will appear if I zoom in/out, which I assume is because I've gone beyond whatever data Pro has cached, but not always. I've tried the refresh button in the lower right-hand corner, F5, and Ctrl-F5, but none work. I've also tried right-clicking on the database connection from the Contents pane, but "Refresh" is usually grayed out. Is there any other option I'm missing to force-refresh the map to show edits made to joined tables? Both the FC and joined (standalone) table in question are on SDE, if that matters. I am using Pro 2.7.3, but this has never worked in any version. Thanks!
