Does anyone know how to add a WFS service to a map using the CIMWFSServiceConnection class?
The WMS and WMTS equivalents work perfect, but when using CIMWFSServiceConnection, the layer that's added to the map has a red exclamation mark in front of it, and the Source entry on the layer's properties dialog shows Data source information not available
This is the code I used for adding a WMS service, the only differences are the URL, and the class used in line 2:
var serverConnection = new CIMInternetServerConnection { URL = "https://example.com/wms?service=WMS" };
connection = new CIMWMSServiceConnection { ServerConnection = serverConnection };
LayerFactory.Instance.CreateLayer(connection, MapView.Active.Map);
Adding a WFS through the user interface (i.e. Favorites > Add Item > New WFS Server) also works without problems.
