I am setting out to write some code that updates the definition of a hosted view join layer. Essentially I would like it to do the following:
1) Enable schema edits on source layers (have been able to get this working)
"hasStaticData" : false,
"sourceSchemaChangesAllowed" : true
2) I then add fields to the source feature layer(s) which I would like to be reflected in the view layer. I send an updateDefinition POST request in an attempt to add the fields to the view definition and at both the feature service or feature layer level it returns as successful. I get:
"success" : true
however the definition remains the same - the fields are still there. The behaviour is the same when I attempt to remove a field as well.
Does anyone have any ideas on why this might not be working? Or if this is even possible?
Hamish
