I am following a use-deep-learning-to-assess-palm-tree-health tutorial. Since I do not have GPU on my computer, I used colab to train the SSD model with arcgis.learn and it was successfully completed.
When I use the trained model (either .emd or dlpk) in "Detect Objects Using Deep Learning" tool, i got error right after model definition selection.
ERROR 002667 Unable to initialize python raster function with scalar arguments. [D:\ESRI_DL\palm_tree_health\ImageChips\models\palmtree_detector_ssd25\ArcGISObjectDetector.py]
File "C:\Users\Kyaw\AppData\Local\Temp\ArcGISProTemp21936\palmtree_detector_ssd25.dlpk\ArcGISObjectDetector.py", line 166, in initialize
self.child_object_detector.initialize(model, model_as_file)
File "C:\Users\Kyaw\AppData\Local\ESRI\conda\envs\arcgispro-py3-dl\Lib\site-packages\arcgis\learn\models\_inferencing\_DynamicSSD.py", line 195, in initialize
self.ssd = SingleShotDetector.from_emd(data=None, emd_path=model)
File "C:\Users\Kyaw\AppData\Local\ESRI\conda\envs\arcgispro-py3-dl\Lib\site-packages\arcgis\learn\models\_ssd.py", line 346, in from_emd
ssd = cls(data, emd['Grids'], emd['Zooms'], emd['Ratios'], pretrained_path=str(model_file), backend=backend, backbone=backbone, ssd_version=ssd_version)
File "C:\Users\Kyaw\AppData\Local\ESRI\conda\envs\arcgispro-py3-dl\Lib\site-packages\arcgis\learn\models\_ssd.py", line 228, in __init__
self.load(pretrained_path)
File "C:\Users\Kyaw\AppData\Local\ESRI\conda\envs\arcgispro-py3-dl\Lib\site-packages\arcgis\learn\models\_arcgis_model.py", line 1300, in load
raise e
File "C:\Users\Kyaw\AppData\Local\ESRI\conda\envs\arcgispro-py3-dl\Lib\site-packages\arcgis\learn\models\_arcgis_model.py", line 1298, in load
self.learn.load(name, purge=False)
File "C:\Users\Kyaw\AppData\Local\ESRI\conda\envs\arcgispro-py3-dl\Lib\site-packages\fastai\basic_train.py", line 269, in load
state = torch.load(source, map_location=device)
File "C:\Users\Kyaw\AppData\Local\ESRI\conda\envs\arcgispro-py3-dl\Lib\site-packages\torch\serialization.py", line 527, in load
with _open_zipfile_reader(f) as opened_zipfile:
File "C:\Users\Kyaw\AppData\Local\ESRI\conda\envs\arcgispro-py3-dl\Lib\site-packages\torch\serialization.py", line 224, in __init__
super(_open_zipfile_reader, self).__init__(torch._C.PyTorchFileReader(name_or_buffer))
AttributeError: 'WindowsPath' object has no attribute 'tell'
I tested with the pre-trained model provided on the tutorial page, it works without any problem.
What could be the problem? Has anybody train SSD on colab for ArcGIS Pro?
