This is a long set of questions, that require some background to answer. Please bear with me pretty new to this software.
I have been testing Survey123 for about 30 days. We are attempting to go out to the public and get them to answer questions (crowd source the data layer) that relate to speed and reliability of their broadband connection in rural areas (9 counties in Illinois). It has been very disappointing that the public, due to Phishing scams, will not respond unless we go out via multiple trusted organizations. We have partnered with some large agricultural organizations and school districts. Right now, we are working on one test county to optimize response rate. I envision using Survey123 across each county 9 agriculatural organizations and several school districts. The survey between the rural and school district has a couple questions that are different. Would eventually like to have a single layer that represents point features that can be symbolized against download, upload and latency speeds.
Question: How/Can I use the same basic survey, but have it go out via multiple "trusted" sources, but in the end only have a single data layer, with minimal steps on my part. Is there a workflow for this?
Question: If I am optimistic, and were to roll out state wide and get good response rates, what is the record limitations of Survey123?
Question: How do I push out a custom map extent of a county or school district poly, in the map to present the public an area they immediately recognize and lessen the mistrust issue?
Question: Within the survey, would like to show a graphic of the broadband speed test, with highlighted circles showing the information we would like them to input into the survey? Basically, an instructional que graphic. I see the image function, but it fits an infrastructure inspection workflow to take a picture or browse to an existing picture. (See attached)
Question: Instead of going straight to Publish, couldn’t there be a beta area to push the survey out prior to the “real” data collection mode. I have been publishing and republishing and then deleting test data over and over. Am I missing something?
Thanks for the help!
