Hi folks,
I've got a quite complicated question about the date field in ArcGIS Pro.
I am using Survey123 to make a hosting feature service/layer and trying to explore and edit the data in ArcGIS Pro. I know that CreationDate field uses UTC, so I used "Convert Time Zone" tool to convert the date and time in Korean Standard Time.
When I looked through the attribute table, the process seems to work very well - converted everything looking good. However, when I click a feature with identify tool, the value is 1899-12-30.
I don't know why this happens even after searching and reading a lot and lot of articles, posts, etc.
I wonder if I have to trust what I see in the attribute table, or in the identification.
Please make some comments if you've ever had this phenomena or found a workaround.
Thanks!
