I have created a survey in Survey123 that includes a map. After publishing the survey, I previewed it and the map extent looks like how I have set it. However, when I have shared the map with users the map is zoomed out and not showing the extent that I had set when creating my survey. The map appears correct for me but each user is getting different map extents when they open the survey. Is there a way to make sure that the map appears with the correct map extent. Thanks.
