I recently upgraded our SDE Enterprise Geodatabase to 10.9.0.2.7 from 10.6.x following an upgrade to our PostgreSQL database to 12.5. I upgraded the Enterprise Geodatabase using ArcGIS Pro 2.7 and had no issues with upgrading the Geodatabase.
However, I've noticed some issues related to tables with geometry columns. For example, when I attempt to run the Check Geometry tool on any registered feature class, I get a validation error that says, "ERROR 003341 This operation is not supported on Esri Spatial Types". This is odd because the geometry type is an Esri Spatial Type because that's what the spatial type was before the upgrade and nothing changed other than upgrading the Geodatabase using ArcGIS Pro. I also know the database host has a valid st_geometry.so file because I was able to successfully enable a new database as a Geodatabase following the upgrade.
Has anyone experienced this type of behavior? Is there a way to check what the spatial type is of a geometry column in Postgres?
Thank you!
