I am running into an issue where a client is experiencing sporadic application crashes which seem to be caused by the RuntimeCoreNETDesktop.dll or msvcr120.dll. We are using ArcGISRuntime 10.2.7.
I have not been able to reproduce this crash on my own machine.
I have a number of dump files from the client, and analyzed them in WinDbg to get the stack traces. These can be seen in the attached document.
Executing !analyze -v produces the same result on each of the dump files:
FAULTING_IP:
msvcr120!abort+28 [f:\dd\vctools\crt\crtw32\misc\abort.c @ 88]
67207666 cd29 int 29h
EXCEPTION_RECORD: (.exr -1)
ExceptionAddress: 67207666 (msvcr120!abort+0x00000028)
ExceptionCode: c0000409 (Security check failure or stack buffer overrun)
ExceptionFlags: 00000001
NumberParameters: 1
Parameter[0]: 00000007
Subcode: 0x7 FAST_FAIL_FATAL_APP_EXIT
ERROR_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application.
EXCEPTION_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application.
With the stack traces, it seems 3 of them are throwing the exception when calling:
10d7f80c 67a73105 RuntimeCoreNETDesktop!VSIVirtualHandle::Truncate+0x11125, calling msvcr120!_CxxThrowException
And 2 of them are throwing the exception when calling:
0fd4fa5c 673332a2 RuntimeCoreNETDesktop!DistanceCompositeSymbol_GetInfos+0xf42, calling msvcr120!_CxxThrowException
Does anyone have any ideas or suggestions on things I can check to determine what is causing these crashes?
