Hello Esri Community,
I know how to load a .TPK File instead of an online base map. I have used the sample esri application map maker in the past to make a small tpk map which puts it in a zip folder and I can just call that.
I have started to learn to use ArcGIS Pro and have began trying to make bigger maps. Do I just need to take the tpk files and put them in a folder and zip or can you just call the files?
This is where I am confused because the maps I've generated before came ready to go. The Maps I created on ArcGIS pro go inside my ArcGIS pro program so I am looking for guidance.
Can you help?
Cheers!
