I have installed and running WebAppBuilder (Dev version 2.13) form several months, which is linked to ArcGIS Online account. Now, I have developed new App with WAB in Portal for Enterprise and I would like to customize some widgets.
So, I have downloaded a new version of WAB (Developers ver 2.19) that I have installed in another local disk in the same computer as WAB v2.13. I have registered an App inside Portal for Enterprise, but when I set App ID I get this error:
| ArcGIS Portal Directory | | |
Invalid redirect_uri
Error: 400
I have checked several times this process, always deleting F:\arcgis-web-appbuilder-2.19\ArcGISWebAppBuilder\server\signininfo.json file, but authentication process always gives the same error.
Also, I have check that there isn't any running instance from previous WAB dev v2.13.
I have to say that I am using the same port 3344 but it is assigned automatically, and I have been using one instance of WAB a time
Is possible to have two versions of WAB in the same local machine? (only running once a time). How?
