I'm not good with attribute rule coding and needing a little help. I'm trying to set up an attribute rule where it will take a field data from a layer and auto populate a field in the related table with the same data. I have run across a few threads where you are populating the layer for the table but not this way. Here is my example (I'm using a SDE SQL)
Hydrant Device Feature Class is Related to Hydrant Maintenance Inspection Table. I want the Utility_AssetID field in Hydrant Device to auto-populate the Utility_AssetID field in the Hydrant Maintenance Inspection Table upon creation of the inspection.
