I created an offline map area and I'm experiencing irregular behavior for one of the map polygon layers. The polygon layer is a filtered polygon in the web map. I'm not sure if this is important. When I create my offline map area, the entire polygon is showing instead of being clipped to the map area extent.
I have not had this happen before. Besides inconsistent behavior, it is also causing the offline map area to be larger than necessary. Actually I think I have had this happen before for reference layers. I'm using the polygon for a related table in the app. I would prefer it be clipped to the map area.
Can you advise? Thanks in advance,
Kathy
