Good evening. I'm trying to create a Building Scene Layer Package as part of my master thesis work on integration between GIS and BIM. I use ArcGIS Pro 2.7 and Revit 2019.
Because i had two linked files of architectural and structural discipline, i followed the workflow first introduced in 2.5 version: i created file a GDB using as input the two separate datasets, i then used this gdb to create a building layer which included the features from both models; the next step would be to use Building Scene Layer Package using as input the building layer ARC+STR, but when i use it as input the following error occurs.
Do you have any idea of why it says this? I thought that creating a GDB file with both the discipline models would have not duplicated all the features in the linked model.
Thanks in advance for your help.
