Is there a known bug where the Survey123 mobile application uses location services all the time - even though the location services is set to only run when the app is in use? This is draining the battery for our users and causing the need to continuously turn the location services on and off every day for the short duration they need to use the app for completing inspections.
Our user has the option selected in location services to only track location when the app is in use. When he closes Survey123, however, the blue bar saying the location is being used continues to appear at the top of his phone. This is when the app is completely closed and will persist until he turns permissions off for location services. His battery is drained quickly unless he turns the permissions off. He is using an iPhone 7, 14.3 version with Survey123 version 3.11.164.
We first experienced this problem several months ago and we could not find a resolution for it. We uninstalled and reinstalled the app, played with location service settings and other settings, and never found a fix. After several weeks / months, the problem went away on its own. It has recently started happening again and we need a solution.
I've seen several threads on this issue although a resolution is never given and for some users, the issue will disappear on its own / reappear at a later date. Is the occurrence of this phenomena associated with iOS or Esri updates? Why is the setting selected in location services not honored on his device?
Related posts:
https://community.esri.com/t5/arcgis-survey123-questions/survey123-uses-location-services-in-background-drains-battery/td-p/805514/page/2
https://community.esri.com/t5/arcgis-survey123-questions/battery-drain-when-using-field-app/m-p/836457#M19743
https://community.esri.com/t5/arcgis-survey123-questions/survey123-field-app-drains-battery/td-p/849682
