Please, add a “Use as ground” entry to the single-band raster layers’ local menu (where the “Symbology” and the “Zoom to Layer” is located”). It would be a perfect tool for DEM comparison (creating profiles, detecting LiDAR classification errors, integrating manual geodetic measurements into remote sensing datasets). Now, I have to add the DEM as Ground and then I have to add the DEM itself as a raster layer. It would be easier to add the raster layer and then right-click and select “Use as Ground” or “Add to Ground” or something similar.
The opposite would be also appreciated: having an entry in a Ground or other surface layers local menu saying, “Use as raster layer”. Alternatively, it could be implemented trough bi-directional drag & drop with Ctrl/Shift/Alt modification key.
This functionality could be introduced into the “Add presets” gallery too: “Add Ground & Raster Layer”.
H.Á.
