Hi! I have a dataset of points that I would like to connect into a network of lines. The points are all given a "circuit" attribute, and so I am looking to connect the points with the same circuit value into a line. I had thought that "Points To Line" tool might do this for me - but I found that the lines end up closed even when I check the "Close Line" box. The result is a very overwhelming spiderweb of lines within the point dataset.
Is there another way that I can generate these lines without digitizing them by hand? I am fine with fixing a couple of small errors along the way - I can proofread the dataset.
Thanks!
