I have written a script that that (should) step through a list of all the tables in a mySql database and write the contents of each to a csv table. I've used this basic construct successfully in the past but with specified tables. This time I'm looping through all the tables in the given database and I'm encountering Unicode errors. For example:
UnicodeEncodeError: 'charmap' codec can't encode character '\x9d' in position 646: character maps to <undefined>
The script roles along and creates a couple dozen csv files without a hitch so I looked at what has been created and figured the next table in the list is the culprit. But I get a different unicode error when I run the script on just that table:
UnicodeEncodeError: 'charmap' codec can't encode character '\u0400' in position 1255: character maps to <undefined>
Clearly I stand to see these sorts of errors every time through the loop. Is there way to trap these errors and then exclude the offending character from the output?
Here's the code, head to toe:
# -*- coding: utf-8 -*-
Created on Tue Dec 22 12:37:49 2020
@author: jborgione
import mysql.connector as mysql
from mysql.connector import FieldType
import csv,os
outFolder = r'N:\GIS\E360'
def createCSV(table):
cn = mysql.connect(user = 'users', password = 'password', host = 'host', database = 'master_db')
cursor = cn.cursor()
table = 'complaints'
query = f'SELECT * from {table};'
cursor.execute(query)
rows = cursor.fetchall()
column_names = [i[0] for i in cursor.description]
dotcsv = f'{table}.csv'
outFile = open(os.path.join(outFolder,dotcsv),'w',newline ='')
myFile = csv.writer(outFile)
myFile.writerow(column_names)
myFile.writerows(rows)
cursor.close
def main():
tableList = []
cn = mysql.connect(user = 'user', password = 'password', host = 'host', database = 'master_db')
allTables = "show tables"
cursor.execute(allTables)
for (allTables) in cursor:
tableList.append(allTables[0])
cursor.close
for table in tableList:
createCSV(table)
if __name__ == '__main__': #if def main exists, call it
main()
