Published survey from Survey123 Connect using an existing feature service hosted on ArcGIS Online. Getting an error from the web version of Survey123 when a Field Worker status user is trying to edit -- "Cannot edit this record because it's submitted by another user." Similarly, when I access the survey on the mobile Survey123 it will not send the edited surveys. The error is simply "Send Error" with the number of surveys not sent. When I tap on the red exclamation point it says, "This survey could not be sent due to the following error: 1483 PLUM CT" (this is coming from my label field for the surveys). The feature service has editing enabled and I don't have any attachments in the feature service.
I need to be able to have a different user edit these using the mobile and desktop web version of Survey123.
@phillipWilson , @JamesTedrick
