Hi Everyone!
I have a list of compliance regulations that need to auto-fill into a notes field when that criteria is selected throughout the survey form. For example: if someone is checking non-compliant standards for a structure, each check-box relates to a specific regulation; I need those to auto-fill in a notes field when selected.
Several questions are select_multiple type, so I understand that I cannot use the Pulldata() function to reference them externally. What is the best solution to create this output?
Can I put them in their own domain list and use the selected() (if selected then display this) calculation? I am still semi-new to using S123 and would appreciate any help for this issue.
Thanks in advance!
