I am having trouble calculating the geometry correctly in ArcPro. Here's what I'm doing: In the attribute table, I right click on the column, select calculate geometry, fill in property (Area), and unit (Square feet (US)) and select the coordinate system. The problem is the area calculated is quite a bit bigger than what it should be. For example a circle with a 3 feet diameter calculates as 75. 7 sqFT. I've gone through trying to use geodesc but with such small areas it shouldn't make that much of a difference. My coordinate systems are the same for the basemap and all my data layers. What am I doing wrong?
Thank you!
